TWK
Fulfill SIL 2 and PL d
The TRK38 from TWK is a singleturn magnetic encoder that was developed with safety-oriented applications in mind.
© TWK
With a diameter of just 38 mm and a length of 38 mm, the TWK sensor is suitable for installation in confined spaces; it weighs around 60 g. The safety encoder detects position and speed and meets the requirements of SIL 2 (IEC 61508) and PL d (EN 13849). The safety-related signals are transmitted via a certified Ethercat FSoE interface. The position resolution is 16 bits per revolution. The Ethercat FSoE interface is used to transmit the safety-related signals to the higher-level controller or to a safety relay and to program the sensor.
Thanks to the aluminum housing and the overall design, the sensor works even under unfavorable conditions such as vibration and shock loads.
TWK
Safety for AGVs
TWK presents the TxSN sensor model with magnetic sensor system in the series of functionally safe sensors with the CANopen Safety interface standard (EN 50325-5).
TWK
Safety encoder for AGVs
The TRK 38 from TWK is a compact and safety-oriented encoder for automated guided vehicles (AGVs) and mobile robots that helps them to navigate in space and move to target positions.
TWK
ATEX and SIL2/PLd certified
TWK has a safety encoder for explosion protection in accordance with ATEX, Zone 1/21. The new generation of encoders with Profinet interface (also with Profisafe profile) is also suitable for Zone 1 (gas) and 21 (dust).
