Schmersal
Four optional functions
Schmersal has further developed the RSS260 safety sensor and equipped it with new software so that it now offers four additional, optionally selectable functions.
© Schmersal
These are: Feedback circuit monitoring (EDM), automatic/manual restart, reset and emergency stop monitoring. In the F0/F1 version, the sensor performs the tasks of a safety relay module - the monitoring of the movable guard and the contactors controlled directly by the sensor outputs is therefore carried out by the integrated logic in the sensor; the use of a separate evaluation device is not necessary.
The sensor with Q function is suitable for machines for which an emergency stop switch is prescribed. Emergency stop switching elements integrated in a series connection can be monitored by the Q function in the last sensor in the chain. This eliminates the need to set up a separate safety circuit for the emergency stop switches. The emergency stop switching elements monitored by the Q function fulfill the requirements up to PL e.
Schmersal
Reliable signal evaluation
Schmersal is launching the SRB-E-302ST safety relay module and the SRB-E-402EM output extension. The safety relay module acts as an evaluation unit for two safety sensors and replaces several modules from the older AES series.
Schmersal
Machine safety made easy
The 'System Engineering Tool' can be used to design complex cable installations for safety switchgear on machines and systems. Users can put together distributors and safety switches using drag & drop. Product Manager Udo Weber explains the...
Schmersal
Safety for set-up operations
The safety function 'Safely limited speed with safety gate open' is relevant for set-up operation or troubleshooting on machines. Below is an example of a safety solution with a redundant encoder and safety controller.
Schmersal
Motto "Sustainable!"
The EU Commission has presented a proposal for a new Ecodesign Regulation for Sustainable Products (ESPR), which is to become a central component of the European Green Deal. Schmersal is also already on the road to sustainability.
