Schmersal
Sensorless standstill detection of drives
With the SSW303HV, the Schmersal Group presents a sensorless standstill monitor that offers significant improvements compared to its predecessor models.
© Schmersal
If dangerous overrunning movements are to be expected on a machine or system, a combination of solenoid interlock (on the safety gate) and standstill monitor (in the control cabinet) ensures the necessary safety. The new standstill monitor from Schmersal replaces a total of fourteen variants from the previous product range. This is made possible, among other things, by the use of a wide-range power supply unit for all common operating voltages (direct and alternating current) from 24 V(DC)/ 24 V(AC) to 230 V(AC). The increased temperature range of -25 to +55 °C opens up additional areas of application. The standstill monitor 'SSW303HV' requires a width of 45 mm in the switch cabinet. The plug-in and coded connection terminals create the conditions for quick and error-free installation. An additional signaling contact provides information about the error status of the module. As the standstill monitor works without sensors, the machine designer does not have to intervene in the 'hardware' of the surrounding construction. The safety module is connected directly to a three-phase AC motor and measures the frequency of the induced voltage directly - for rated motor voltages of up to 690 V. The safety contacts for enabling an interlocking device close as soon as the motor comes to a standstill. The standstill monitor can be used in safety circuits up to category 4 / PL e in accordance with EN 13849-1 and SIL 3 in accordance with EN IEC 61508.
Megatron
Angle measurement in the smallest space
Thanks to their housing depth of just 6 mm and a housing diameter of 16.4 mm, the hollow-shaft conductive plastic potentiometers in the 'MHP16' series from Megatron are particularly suitable as position indicators in motor valves and actuators.
Schmersal
Participation in the start-up Aconno
Schmersal acquires a 26% stake in Aconno. The Düsseldorf-based start-up develops customer-specific hardware, Bluetooth and sensor solutions as well as software for the areas of digitalization, the Internet of Things and Industry 4.0.
Schmersal
Motto "Sustainable!"
The EU Commission has presented a proposal for a new Ecodesign Regulation for Sustainable Products (ESPR), which is to become a central component of the European Green Deal. Schmersal is also already on the road to sustainability.
