Georg Schlegel
For machine life-long use
The IP69K combi pushbutton emergency stop is designed for mobile machines and special vehicles that are exposed to difficult environmental conditions. It was developed in a joint project between Data Panel and Schlegel.
© Georg Schlegel
The overmolded emergency stop from Data Panel and Schlegel offers protection class IP69K on the front. IP65 protection is guaranteed on the rear when the cable is connected. On the inside, a Gore seal ensures that no moisture can penetrate while allowing air to pass through. The plastic has also been optimized for outdoor conditions: The emergency stop is UV-resistant so that it does not fade even in the long term, but retains its signal yellow color. The high-pressure cleaner-resistant MDC04-4P plug interface with UV and abrasion-resistant 4 mm x 0.75 mm PUR sheathed cable is used to connect to the DEUTSCH plug. With the appropriate connection cable (7072-72161-569xxxx), longer distances in a machine can be bridged using 'plug and play'. The emergency stop is also available with an M12 connection.
Georg Schlegel
Suitable for rail transport
The Schlegel charging sockets are available in three versions, each with two USB ports from the combinations of USB-A and USB-C: A/A, A/C and C/C. The USB-A port delivers up to 2.4 A, the USB-C port up to 3 A charging current at 5 V output voltage.
