Georg Schlegel at SPS 2023
Suitable for railroad applications
Schlegel's charging sockets are available in three versions, each with two USB ports from the combinations of USB-A and USB-C: A/A, A/C and C/C.
© Georg Schlegel
The USB-A port delivers up to 2.4 A, the USB-C port up to 3 A charging current at 5 V output voltage. This also allows two devices to be charged at the same time. The sockets by Schlegel have a current limitation of the output current for each USB port including short-circuit protection as well as under- and overvoltage protection. The charging sockets can be operated in the temperature range between -40 and 70 °C. At high ambient temperatures, a temperature sensor ensures that the electronics do not heat up too much. It regulates the charging current accordingly or automatically switches off the charging process when the critical temperature is reached. Ventilation slots also ensure continuous cooling. The charging sockets are suitable for use in railroad applications and comply with EN 50155, EN 61373:2011 Class 1B, EN 60077-1, EN 45545-2, EN 60068-2, EN 50121-3-2, IEC 61000-6-3/4 and EBA EMV06 standards for all relevant parts.
Hall 9, Booth 456
Georg Schlegel
Suitable for rail transport
The Schlegel charging sockets are available in three versions, each with two USB ports from the combinations of USB-A and USB-C: A/A, A/C and C/C. The USB-A port delivers up to 2.4 A, the USB-C port up to 3 A charging current at 5 V output voltage.
Hanover Fair
E-Paper: HANNOVER MESSE DAILY Day 5
The top news of the issue on the fifth day of the trade fair in Hanover: First summary of Hannover Messe 2023 +++ Interview: Bosch Rexroth +++ Igus: manus awards presented +++ Interview with Markus Asch, Rittal +++ The trade fair partner country 2025
Georg Schlegel
For machine life-long use
The IP69K combi pushbutton emergency stop is designed for mobile machines and special vehicles that are exposed to difficult environmental conditions. It was developed in a joint project between Data Panel and Schlegel.
Georg Schlegel
Modular bus system expanded
The modular bus system MBS from Georg Schlegel is a proprietary bus system that can be integrated into fieldbus systems such as Profibus DP, AS-Interface or CANopen as well as industrial Ethernet networks such as Profinet, Ethernet/IP, Ethercat or...
