Human-robot collaboration / cobots
New ISO standard for the measurement of collision forces
In collaboration with numerous international partners, robotics experts at the Fraunhofer IFF have developed a new ISO standard that shows how contact forces and pressures on cobots will be measured in a standardized way in the future. The ISO standard has now been published.
At work: A cobot from Universal Robots with a sanding kit from Robotik
© Robotics Consulting
Cobots make manual work less tedious and more interesting - and help manufacturing companies to secure their sites in the long term. However, collaborative robots place higher demands on user knowledge in terms of safety, as humans and cobots can and may work together directly. The EU research project COVR has therefore developed a digital contact point that helps companies to share knowledge and secure cobot applications.
Based on the project results from COVR, the scientists at the Fraunhofer IFF have been working with international experts since September 2020 to develop a new standard for measuring contact forces and pressures on cobots that are safeguarded by "power and force limitation" (in accordance with ISO/TS 15066, compliance with biomechanical limit values). This resulted in the ISO standard "ISO/PAS 5672:2023", which was recently published. The normative document combines the latest knowledge from science and measurement practice, which simplifies the metrological testing of cobots. It now provides a standardized basis for the safe collaboration of humans and robots.
The new standard was developed in the working group "ISO/TC 299 WG 8: Validation methods for collaborative applications". Under the leadership of Dr. Roland Behrens (Group Manager Model-based HRC Integration and Safety at the Fraunhofer IFF), the working group investigated the question of how different regulations in the ISO member states can be standardized and supplemented with the latest scientific findings in a beneficial way. This was the only way to specify a standardized and consensus-based testing practice for future cobot applications. "The original regulations at national level did not adequately cover this issue, and many points were still open or sometimes contradictory," says Behrens, describing the initial situation. "This is where the project results from the COVR project were ideal. We are excited to see what impact the standard will have on the world of robotics and safety in human-robot collaboration. However, I can already reveal that the next ISO project will significantly simplify the test acceptance of cobots."
Special
Robotics&AUTOMATION 3/2021
Is an industrial robot without a cage really safe? What needs to be considered in the planning phase of human-robot collaborations? And what does a gecko have to do with robotics? The latest e-paper from Robotics&AUTOMATION provides the answers.
Fraunhofer IFF
Secure cobot installations
When it comes to safety, cobots place high demands on the knowledge of their human colleagues. A digital service developed by European research institutions aims to help companies share knowledge and carry out safe cobot installations.
Machine Learning
Apply according to plan
Procedures and processes in manufacturing can be optimized through the use of machine learning. However, machine learning is still far from being a standard tool. Fraunhofer researchers have now developed a generally applicable process model.
