Conveyor systems:
Quelle: Melkus Mechatronic | Lukas Dehling,
Flexible alignment of the load carrier
The Agumos Q40 from Melkus Mechatronic is an automated guided vehicle system developed for the automated transportation of small parts, which are often transported in stackable 60 x 40 cm boxes.
© Melkus Mechatronic
With a footprint of 40 x 40 x 40 cm, the system can also be used in narrow production aisles and warehouse aisles. The ability to flexibly adjust the height and direction of rotation of the load carrier should ensure a high level of ergonomics and make it easier to adapt to existing facilities. A 360-degree rotation function of the load carrier was developed to keep the load in a defined alignment, even if the transporter changes its direction of travel. An integrated laser scanner ensures a safe stop in front of people and unexpected obstacles. According to the manufacturer, the free-moving industrial truck with a payload of 60 kg is quickly ready for use thanks to variable, optical track guidance and can be easily integrated into existing systems. It communicates with the mobile operating device via radio and with the control system via WLAN. Transport orders can be managed here.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
