Cincoze
Embedded PC for AMR applications
The 'P1201' embedded computer from Cincoze is ideal for use in autonomous mobile robots (AMR).
The 'P1201' from Cincoze has a compact size of 204.5 mm x 149 mm x 41.5 mm, making it suitable for installation in limited space in an AMR. In terms of performance, it features the Intel Atom x6425E quad-core processor (Elkhart Lake platform). Compared to the previous generation (Apollo Lake), the performance per core has been increased by up to 1.7 times and the multi-core performance has been improved by 1.5 times. It supports up to 32 Gbytes of DDR4 memory at 3200 MHz. With its energy consumption of just 6 or 12 W (TDP), the embedded PC makes a positive contribution to the performance capacity of an AMR and helps to reduce loading times, according to the manufacturer.
AMRs rely on cameras and lidar, among other things, to perceive the environment, control autonomously and plan routes. I/O interfaces are therefore important: in addition to the native I/O connections (1GbE LAN, USB 3.2, COM and DIO), the embedded PC also supports expansion modules. For wireless connections, the computer offers an M.2 Key E slot that supports Wi-Fi 6 / Intel CNVi / Bluetooth modules for fast data transmission. In addition, a Mini PCIe slot for a GNSS/4G module is available to facilitate communication between AMRs and make real-time information accessible to monitoring personnel.
