Delta robot
Quelle: Igus | Inka Krischke,
DIY kit or pre-assembled
The drylin DLE-DR delta robot from Igus uses lubrication-free tribo-polymers, making it inexpensive to purchase and low-maintenance to use.
© Igus
Thanks to the modular system, users can choose between a compact do-it-yourself kit or a pre-assembled version in a transport frame. The robot consists of three maintenance-free 'drylin ZLW' toothed belt axes with NEMA23 XL encoder stepper motors, lubricant-free 'igubal' coupling rods and matching adapter plates for grippers and motors. This enables fast handling of up to 5 kg with a precision of ±0.5 mm. The Delta robot offers a working area with a diameter of 660 mm and a height of 180 mm. A calibration mandrel enables the robot to be positioned at the zero point. It is fixed to the mounting star. The Delta robot is particularly suitable for simple assembly tasks, pick & place tasks and applications in testing technology. It can be assembled as a kit in around 30 minutes.
Low cost robotics
Igus announces 'ROIBOT Award
The 'ROIBOT Award', which Igus is presenting for the first time, is intended to recognize clever applications with a quick return on investment based on cost-effective robot technology from the Cologne-based company. Interested parties can register...
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
