Human-robot cooperation
Darius Wilke | Günter Herkommer,
Addressing the skills shortage with cobots
Countering the shortage of skilled workers and at the same time upgrading existing jobs - these are the reasons for using collaborative robots in various industries. - Two practical examples.
© Rethink Robotics
Founded in 1984 as B&D Plastics, the US company Cox Container currently operates several blow molding machines. These are in operation 24 hours a day in the 73,000m2 production facility. In order to be able to meet individual customer requirements, it is essential for the blow mold manufacturer to work extremely flexibly - both in terms of employees and machine deployment. In other words, it is important to be able to constantly switch between high-volume/low-mix and low-volume/high-mix models.
Sawyer uses the built-in camera system to recognize which part it needs to process first and places it in the grinding machine accordingly.
© Rethink Robotics
Like many other manufacturing companies, Cox Container has great difficulty in recruiting and retaining qualified specialists in the long term. In one work cell in particular, where two employees had to pack bottles, there were often bottlenecks: The pace of work was too fast for one employee, but still too slow to justify a second employee in the same cell.
The ideal solution to the problem for Cox Container was to use a collaborative robot in the cell: the cobot - specifically the Sawyer from Rethink Robotics - has since been supporting the individual employee in packing the bottles. Plant manager Gary Fox: "With Sawyer, we have reduced the number of staff required in this specific work cell by 50% and have been able to deploy three employees in other areas of the company as a result. This not only allows them to do more valuable and meaningful work. It also means the employees stay with us longer."
Rethink Robotics has adapted the ClickSmart grippers to the application at Cox Container so that Sawyer can place several bottles in the container at the same time thanks to the extended gripper.
© Rethink Robotics
In detail, Sawyer picks up bottles from a conveyor belt in the production facility and places them in a specially designed container. The collaborative robot is trained to switch to another picking area as soon as the container is half full. There it selects a carton divider, places it in the container and then fills it with a second layer of bottles. After completion, the operator hands Sawyer a new container for packing and finally carries out the final packing of the bottle bundle.
"Sawyer was up and running for us within a day and we expect an ROI within the next six to eight months," says Gary Fox. Next year, Cox Container plans to deploy additional collaborative robots on three other production lines.
CNC production gains speed
Cobots like Sawyer are very well suited to CNC machine assembly: The work is monotonous and repetitive. This increases the likelihood of errors when loading and unloading the workpieces to be processed.
© Rethink Robotics
Change of scene: Fitzpatrick Manufacturing, a CNC contract manufacturer also based in the USA, uses the Sawyer collaborative robot at its plant in Sterling Heights in the US state of Michigan. The company was founded in 1952 and serves a wide range of industries including aerospace, automotive, medical devices and oil and gas.
The Fitzpatrick team knew that the choice of application for Sawyer would be critical to the success of the smart automation solution. Team Leader Jon Mutz: "We looked closely at the question of the right use of Sawyer, especially because it is difficult to predict which project to implement next in contract manufacturing. Sawyer's versatility ultimately allowed us to automate repetitive, monotonous tasks and free up our employees for more skilled and demanding work."
After the first half of the container has been filled with bottles, the Cobot independently selects and places a carton divider and continues its work in the second half.
© Rethink Robotics
Specifically, the robot helps Fitzpatrick Manufacturing to grind parts that serve as components for drive technology solutions. Such tasks require precise adherence to tolerances and involve many repetitive operations. Sawyer recognizes which part he needs to process first and loads the grinding machine accordingly. When the part is finished, the cobot removes it and loads another part into the machine. It then places the first part in the washing station. In the next step, Sawyer dries the workpiece on a blower unit before packing it in a box for dispatch.
Between 280 and 300 parts can be packed in this way without the intervention of an employee. This process takes between five and eight hours, so Sawyer can easily work overnight. When the employees start their shift the next day, the smart helper has already completed all the parts.
"When we started using Sawyer in production, the employees were a little reluctant at first," recalls Jon Mutz. "The older colleagues didn't quite know what to make of the new technology, while the younger staff were enthusiastic. From the moment our team realized that Sawyer was not there to replace their workforce, but to help them use their skills for more meaningful tasks, Sawyer was accepted and appreciated by everyone."
Author:
Darius Wilke is Director European Business at Rethink Robotics.
Fraunhofer IAPT
360-degree view for robots
Robots working on detailed workpieces need to know where the workpiece is at all times. The more precise, the more difficult. Researchers at the Fraunhofer IAPT have now developed an improved visual aid for industrial robots.
