Data module
Meinrad Happacher,
TFT displays almost at OLED level
Data Modul took a new approach to controlling the LED backlight of a TFT. The result is a TFT series with Full Array Local Dimming (FALD) technology.
The FALD technology from Data Modul: Contrast and color are at OLED level.
© Data module
The TFT series with FALD technology achieves a picture performance that comes very close to an OLED. The advantages of FALD technology compared to conventional backlight technology are OLED-level contrast and color, superior image quality and excellent readability even in sunlight. In addition, power consumption is significantly lower compared to similarly bright displays. This makes the new series ideal for the automotive industry, medical imaging or marine applications.
The first display in this series is the 7" WUXGA display, which has a high contrast with 360 zones and an ultra-wide color space of 105% DCI-P3. The 10-bit panel with MIPI interface has a typical brightness of 1,800 cd/m² at an operating temperature range of -20 °C to +70 °C and has an InCell touch.
Data Modul is also planning to expand its FALD range in the medium term with a 10.1" FHD display as well as 13.3", 17.3" and 24" UHD displays. All displays are offered in combination with a suitable HDMI (or DP input) control card for signal and backlight control.
Mass
Large display included
Mass offers industrial computers with a large display, which are arranged in front panels as PPCs (panel PCs) or free-standing as SACs (stand-alone computers).
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
