KEB Automation
Available in four sizes
KEB Automation has launched the 'Web HMI C6 X1'. The panel can be flexibly attached anywhere on the machine thanks to various mounting options.
© KEB Automation
The panel from KEB Automation is equipped with capacitive multi-touch and supports Power-over-Ethernet (PoE). The possibility of installing the Web HMI outside the control cabinet is also facilitated by protection class IP67, which enables use in an extended temperature range of -20 to +55 °C without an additional housing. Users can choose between four sizes: 7 inch, 10.1 inch, 15.6 inch or 21.5 inch. The systems have a Linux operating system and are equipped with a Chromium-based HTML5 browser. According to the manufacturer, this makes them particularly suitable for IIoT edge applications in industry. In combination with tools such as 'Helio', the Web HMI can be used to create an innovative visualization system, for example. Helio is an HMI management system that allows users to create intuitive HMIs.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
