Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and automation technology.
© Wöhr
According to Wöhr, the robust design combined with protection class IP65 prevents the ingress of dust and splash water. According to the provider, the keyboards are easy to install and integrate into existing devices and systems. The antibacterial front foil (ABAK) and the cleaning button ensure operability in both hygienically demanding and typical industrial environments. The antibacterial front foil can be individually adapted and designed to customer requirements. The layout is available in German and English as standard, other country-specific layouts are possible.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
E-T-A
Sensory in view
Intelligent power distribution systems are valuable helpers when it comes to digitalization in the IT rack. Monitoring the IT racks using sensors is a particularly effective measure for increasing system availability.
Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
