SR System Electronics
Available as a touch monitor or panel PC
© SR System Electronics
SR System Elektronik launches a 10-inch touch panel on the market, which is available as a 'V-Flat 10' touch monitor and as a 'V-IPC 10' panel PC.
The touch panel from SR System Elektronik is fully compatible with the IEEE 802.3at standard, allowing it to be operated via PoE+. This enables a simplified power supply via the Ethernet cable, which reduces installation effort and optimizes use even in areas that are difficult to access. The monitor has a TFT display in 16:10 format with a resolution of 1280x800 pixels. The capacitive MultiTouch surface recognizes several touch points simultaneously, enabling intuitive, precise operation. The front of the touch panel is designed as a flat glass surface. The continuous glass front is protected against dust and water jets in accordance with IP65. The device is housed in an aluminum-metal casing. The touch panel can optionally be fitted with a cover for the connections, which protects the connection points from splash water and unauthorized manipulation. Integrated loudspeakers are also available as an option.
