ICO Innovative Computer
Panel PCs in a demanding environment
The 'Hygrolion' panel PCs from ICO Innovative Computer offer resistance to water, dust, heat and cold with a robust stainless steel housing, full IP69K protection and an extended temperature range of -20 to +60 °C.
The fanless design makes the devices from ICO low-maintenance and suitable for environments with high hygiene and cleaning requirements. The Panel PCs are available in 15, 19 and 21.5 inch sizes. Inside, Intel Celeron J6412 processors with 2.0 GHz ensure smooth performance for control and visualization tasks. The devices are equipped with 8 Gbyte RAM as standard - expandable up to 16 Gbyte - as well as a 256 GBbyte SSD for fast system start-ups. The connection options include 2x Gigabit LAN connections, 2x USB 2.0 ports and two serial interfaces that can be used as RS232. WLAN support is also integrated. The devices are compatible with Linux and Windows 10 and 11 operating systems.
