Load cells:
Quelle: Flintec | Inka Krischke,
Overload-resistant and highly accurate
The design of the Flintec DSB7 series load cells, which can be integrated into the vehicle, enables uncomplicated installation without extensive modifications to the chassis.
© Flintec
Thanks to nominal loads of 7.5, 15 and 25 t, the load cells can be used in most commercial vehicles including light trucks, tipper trucks, refuse and recycling trucks, heavy-duty trucks and agricultural vehicles. Depending on the version, the series achieves an accuracy of better than 0.15 %, 0.25 % or 0.5 % of the compound error and a 300 % overload resistance. Each load cell is supplied with a manufacturer's test certificate. Due to the often harsh operating conditions in vehicles, the load cells are made of stainless steel, are hermetically sealed and meet the requirements of protection class IP68. The load cells are connected via a 5 m cable and a 4-pin M12 connector.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
