Fraunhofer IPMS and Dive
Semiconductor Processes optimized
Together with Dive imaging systems, the Fraunhofer Institute for Photonic Microsystems IPMS has established a step towards resource-saving semiconductor production. The installation of an optical measuring device from Dive in the Fraunhofer IPMS clean room has significantly reduced the amount of inspection work required during wafer production.
Imaging systems from DIVE enable non-destructive wafer inspection © Dive imaging system
During semiconductor production, up to 1500 process steps are carried out, including etching, deposition and lithography. Accordingly, there is a high potential for errors, while finished wafers should be virtually defect-free due to their highly complex structures. In order to guarantee these high quality standards, sometimes almost 50 percent of the process steps are accounted for by accompanying metrology processes; several thousand additional control wafers are often required per month. This procedure therefore requires a considerable amount of additional work and therefore more financial and material resources as well as additional energy and time.
The 'NEST' project (New Screening Tool for Efficient Semiconductor Manufacturing) has addressed precisely this problem: Within an environmental potential analysis conducted by Dive, Fraunhofer IPMS and Fraunhofer IZM over the last 1.5 years, it was determined that targeted inspection tools can not only save at least 25 percent of inspection wafers, but also more than 118,000 kg ofCO2 emissions per month during production. Dive uses innovative spectroscopy and imaging technology that makes it possible to identify defects in deeper layers. The calculations were based on the conditions of a 28 nm production process and 25,000 wafer starts per month. The project was funded as part of the 'Green ICT Space' of the Research Fab Microelectronics Germany (FMD).
In addition to the general reduction in emissions, the use of such screening tools offers further ecological advantages such as the saving of water and chemicals used in the production of control wafers. There is also an economic advantage if a large proportion of additional metrology steps can be saved. This is because the general energy balance is also improved by the reduced tool occupancy that would otherwise be caused by control wafers. Process deviations can be detected at an early stage, production errors are avoided and the productive wafer yield is positively influenced.
Industrial evaluation in the Fraunhofer IPMS clean room
Dive imaging systems develops inspection tools that combine the advantages of optical spectroscopy with imaging. The 'VEpioneer' system is the first system from Dive to operate under cleanroom conditions. It detects surface properties, contaminants and deviations from production specifications within 20 seconds. This rapid inspection and the additional use of AI algorithms make the process steps in semiconductor production comprehensively controllable and reduce testing costs. "Dive's hyperspectral imaging systems offer a new possibility for non-destructive testing of entire wafers. With the support of Fraunhofer IPMS, this innovative technology is now available for use in standardized industrial cleanrooms - enabling significant productivity increases and cost reductions for semiconductor factories," says Martin Landgraf, R&D Manager at Fraunhofer IPMS.
Even after the successful completion of the project, the 'VEpioneer' system will remain at the Center Nanoelectronic Technologies (CNT) of Fraunhofer IPMS, where it will carry out further wafer measurements and evaluations for customers and partners. In further joint projects, the system is also to be further developed in the future with automation of wafer handling and equipment coupling for automatic data transfer. The takeover of Dive imaging systems by PVA Tepla opens up further evaluation and development opportunities for the start-up.
