Process controller
Quelle: Jumo | Inka Krischke,
Four instead of two control channels
The functional scope of the Dicon touch process and program controller from Jumo has been expanded with numerous new features. Extensive regulation and control tasks can now be implemented via four control channels instead of the previous two.
© Jumo
This means that several control zones can be managed with just one device to save space. The process controller now offers 16 math and logic formulas as well as four timers. Time-controlled processes can also be flexibly implemented in the new version via 32 user programs and 16 control contacts. The integrated recording function also enables tamper-proof data acquisition of eight analog and 16 digital values. Thanks to the control algorithm, the modular design and the communication options via the USB host, USB device, RS422/485 Modbus master or slave, Profibus DP, Ethernet and Profinet IO device interfaces, the process controller can be individually adapted to the respective requirements.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
