Nivus
Flowmeter with IoT function
Nivus offers the 'Nivuflow' devices with a mobile radio modem with worldwide approval. The manufacturer's IoT concept allows the operator automatic data transmission in conjunction with many visualization and logging options.
© Nivus
Measurement data and system data as well as fault messages or alarms from the flowmeters can be transmitted directly via mobile radio. With this extension, Nivus is able to offer a faster device service. The options for remote maintenance, remote diagnosis and remote commissioning reduce time-consuming journeys for service work to a minimum.
By using 'Nivus Connectivity', the Multiroam SIM chip automatically uses the strongest available mobile network. The operator has the advantage of calculable costs, as the provider does not charge roaming costs. The data is made available on the 'Nivus WebPortal' and transferred to other systems as required. Data transmission complies with the IT security standards of DWA, DVGW and BSI.
Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flow meter is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the supplier.
