Vegetables
Contactless and precise volume flow measurement
Gemü launches the ultrasonic flowmeter 'Gemü 3040', which is used to determine conductive and non-conductive volume flows of liquids without contact.
© Vegetables
The ultrasonic flowmeter is available in nominal sizes from DN 10 to 50. It has no moving parts in the area in contact with the medium. Both conductive and non-conductive media can be measured in a pressure range from 0 to 16 bar with a measuring accuracy of 2 % of the actual measured value. The flow meter operates in the temperature range from -10 to +80 °C.
Thanks to the high-quality plastic body, the flow meter can be used for aggressive media such as acids and alkalis. The standard illuminated display allows programming to be carried out directly on site. All important operating parameters can also be read directly on the flowmeter. According to Gemü, the measuring device comes with integrated empty pipe monitoring and a flow meter as standard. Standard electrical and mechanical connections are available for integration into the application.
Nivus
Flowmeter with IoT function
Nivus offers the 'Nivuflow' devices with a mobile radio modem with worldwide approval. The manufacturer's IoT concept allows the operator automatic data transmission in conjunction with many visualization and logging options.
AMA Association
Slight decline in incoming orders
The sensor and measurement technology sector recorded no change in turnover in the third quarter of 2024 compared to the previous quarter. However, turnover fell by 10% compared to the third quarter of 2023. Incoming orders were 2% below the level...
Vega Grieshaber
Chip start-up founded
The start-up milli IC from Karlsruhe specializes in the development of ASICs - and Vega Grieshaber is 'on board' to ultimately develop radar measuring devices with radar frequencies of more than 100 GHz.
