Tebis
Parametric-associative system basis
Tebis has launched Tebis 4.1. With the complete parametric-associative CAD/CAM system, design, manufacturing preparation and CAM programming tasks can be completed in a single system, in some cases highly automatically.
© Tebis
The parametric-associative system basis is specially tailored to the requirements of single part and small series production, in which tight delivery deadlines, frequent component changes, a high number of variants and different data qualities determine everyday life. This is why the system does not differentiate between surfaces or open and closed solids. All objects can be blended together without this leading to error messages.
User guidance is based on the logical approach of CAD designers and CAM programmers. In the CAD node, users view CAD elements and easily adapt parametrically associative designed objects based on the creation history. Similarly, the CAM node of the tree contains the work plan. CAM programmers use the work plan and the 'Tebis NCJob' technology to generate and manage all NC programs for all technologies required to manufacture a part. The user interface can be individually configured.
Simus Systems
Capture drawing information with AI
Version 11.8 of 'Simus classmate', a digitization solution for manufacturers and suppliers in mechanical and plant engineering from Simus Systems, integrates drawing information with 3D models using artificial intelligence (AI) and transports it to...
