Core technology
Reliably compare 3D data
The current version of the 3D_Analyzer viewer and analysis software from CoreTechnologie has the option of adding 3D annotations and views to automatically determined geometry differences.
© Core technology
The CoreTechnology software can also save in JT, Step 242 and 3D PDF format in addition to its native format. This allows project engineers and designers to make new component versions and geometry changes transparent when editing product data. The geometric model comparison determines all changes between two CAD models and displays them in color on the two model versions. The user can then take measurements, add any comments to the models and create different views. The neutral formats can be used to document the determined changes and pass them on to external partners, enriched with information.
In addition, the changes documented in the 3D model can be directly zoomed and optimally aligned using the saved views. Deviations are measured on the exact CAD models.
Tebis
Parametric-associative system basis
Tebis has launched Tebis 4.1. With the complete parametric-associative CAD/CAM system, design, manufacturing preparation and CAM programming tasks can be completed in a single system, in some cases highly automatically.
Simus Systems
Capture drawing information with AI
Version 11.8 of 'Simus classmate', a digitization solution for manufacturers and suppliers in mechanical and plant engineering from Simus Systems, integrates drawing information with 3D models using artificial intelligence (AI) and transports it to...
