iTAC Software
Generating added value from machine data
iTAC.SMT.Edge from iTAC Software enables the standardization and centralization of machine data, especially in SMT production.
© iTAC Software
The data is merged on the store floor using a machine integration platform based on an edge solution and distributed to higher-level systems such as MES, ERP, etc. via a direct interface. There is an extensive library of specialized software interfaces for each device type from different manufacturers, which can be connected using configurable adapters.
The iTAC Software solution enables the acquisition of manufacturer and platform independent machine data in any format, via a standard protocol or proprietary. Thanks to different interface types, operators can select which machine with which interfaces is involved. Once entered, the system recognizes the communication type and delivers the corresponding data.
Wibu-Systems
Protection for intellectual property
In the industrial environment, extensive data input is generated from a wide variety of sources, which is often processed with the help of artificial intelligence applications. How can the good ideas behind this process be effectively protected?
