Controls
Quelle: Griessbach | Inka Krischke,
Extended range of functions
Griessbach presents a control system for interior, transition and WC doors in rail vehicles: According to the company, the 32-bit module is characterized by a significantly increased range of functions.
© Griessbach
For example, an inclination sensor system has been implemented that allows the door behavior to be precisely adjusted to the vehicle inclination via the door motor control, for example when cornering. The improved and smooth-running reversing function for obstacle detection reliably protects passengers and staff from crushing and pinching hazards, even at high door speeds. The integrated firmware offers various parameterization options to adjust the control unit flexibly and precisely to the individual door characteristics such as number of leaves, door weight, opening width and speed. In addition to direct current motors, three-phase motors can also be controlled. An energy-saving OLED display with a wide reading angle has been integrated for clear, high-contrast visualization of operating states, counter statuses, diagnostic and service information. Five navigation buttons are available for operation. In the standard version, the modules have two CAN interfaces for connection to the train bus system. If required, the manufacturer can also equip the control unit with interfaces for Ethernet, Profinet or TCP/IP. Two USB 2.0 interfaces are installed as standard for parameterization, service functions and software updates. The 32-bit controller meets all current standards with regard to temperature resistance, vibration and shock resistance in railroad operation. With its PC-ABS housing, it complies with the current fire protection standard EN 45545.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
