Industrial PCs
Quelle: noax Technologies | Inka Krischke,
Vehicle terminals with WLAN connection
The industrial PCs from Noax can be optionally equipped with the WLAN standard IEEE 802.11a/b/g/n and increase both data transmission security and range.
© noax
This applies in particular to the C12 and C15 IPCs, which can be used in both stationary and mobile applications. The integrated WLAN antennas of the vehicle-mounted terminals make installation easier, both in stationary installations and in the often quite narrow industrial trucks. The integration into the housing also prevents the antennas from breaking off. To ensure continuous data transmission without interruptions, the provider's forklift truck terminals have two integrated antennas. There is also a solution for use in almost closed industrial trucks, where reception problems can occur due to the Faraday effect, to ensure data transmission via WLAN: Here, remote antennas are mounted outside the vehicle, for example on the vehicle roof. Here, the connection is made via the connector area.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
