CANopen
Profiles for J1939 networks
The CAN in Automation Association (CiA) has published the CiA 406-J and CiA 410-J specifications, which specify the mapping of CANopen profiles for rotary encoders and inclinometers for J1939 networks.
The current CAN in Automation board: Uwe Koppe (MicroControl), Holger Zeltwanger and Christian Schlegel (HMS) (from left to right)
© CAN in Automation
Both application layers, CANopen and J1939, are used in mobile machinery. Many manufacturers have implemented the CANopen profiles. To ensure that these products can also be used in J1939 networks, CiA has applied for and received corresponding parameter group numbers (PGNs) from SAE International. In order to be able to configure the sensors as in CANopen, the CiA 510 specification was also developed. It describes the mapping of the CANopen SDO protocols to J1939. The parameter groups CAM11 and CAM21 are used for this purpose. A mapping of the CANopen EMCY message is also specified.
"With these CiA specifications, it is very easy to use CANopen profiles in J1939 networks," explained Holger Zeltwanger, CiA Managing Director. "In the past, this was done on a company-specific basis, which made it difficult to exchange products from different manufacturers." CiA 510 standardizes the configuration of devices that support a CANopen profile. "The J1939 sensors implement a virtual CANopen object dictionary that can be accessed via CAM11 and CAM21," says Zeltwanger.
esd electronics
Migration to CAN FD
In 2011, work began to push the existing limits of classic CAN in terms of the maximum achievable data rate - the idea of CAN FD was born. But is it really worth migrating to CAN FD now?
What do you think?
TSN alone is nothing!
Yes, TSN is the new basic technology for convergent real-time communication. But which protocols will actually be based on the TSN layers and become established on the market has not yet been decided. In this article, four protagonists have their...
CANopen FD
Tips for device and network design
A higher transmission rate and more user data per message - with this goal in mind, the classic CAN protocol has been expanded to include the FD version. Developers are now faced with the question of the ideal design for corresponding devices and...
Fieldbus technology
The future of CANopen
Similar to the automotive industry, industrial automation also requires more and more bus bandwidth. In addition, the cloud is becoming increasingly important in terms of communication. How does the CAN protocol, which has long been established in...
