Bihl+Wiedemann
Integrated IO-Link master
Whereas a 4- or 8-port master with an Ethernet connection was previously essential for the integration of perhaps just a single IO-Link device, Bihl+ Wiedemann now offers ASi-5 modules with one, two or four IO-Link master ports in various versions.
If data only needs to be collected from individual, decentrally distributed IO-Link devices, the company has a cost-effective solution in the form of the BWU4088 and BWU4077 active distributors with one or two IO-Link master ports. Both modules are designed with IP67 protection, are supplied from AUX and can be easily connected to the yellow ASi cable as ASi-5 modules using piercing technology.
The IO-Link devices are connected via one or two M12 cable sockets. BWU 4088 has one Class B IO-Link port, BWU4077 has one Class A and one Class B port.
If data needs to be collected from more IO-Link devices in the field, there are suitable field modules with four IO-Link ports, depending on requirements. The BWU3819 and BWU3899 modules both have four Class A IO-Link ports, while the BWU4067 and BWU3897 modules are both equipped with two Class A IO-Link ports and two Class B ports.
While the first module is connected via the ASi profile cable, the second is connected via M12. The IO-Link devices are connected via 5-pin M12 sockets on all four modules. If the IO-Link devices to be integrated are located near the control cabinet, the BWU3843 control cabinet module in IP20 is ideal. The module also has four IO-Link ports, whereby the use as port A or port B can be defined via configurable terminals.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade MediaSubscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
