Process automation
Quelle: Endress+Hauser | Inka Krischke,
Configure and parameterize field devices easily
Endress+Hauser is now offering the Field Xpert tablet PC together with Softing's mobiLink interface as a bundle for parameterization and commissioning of field devices.
© Endress+Hauser
According to the manufacturer, this combination offers users a secure system solution for configuring and parameterizing field devices for the most important process automation protocols - HART, Profibus PA and Foundation Fieldbus. The bundle includes a 'Field Xpert SMT70' or 'SMT77' tablet with pre-installed CommDTMs, a 'mobiLink' interface that establishes the connection to the tablet via Bluetooth and an optional license to use 'mobiLink' for the configuration of Foundation Fieldbus and Profibus PA field devices. 'mobiLink' is available from Endress+Hauser under the name FieldPort SFP50. The tablet PC for device configuration can be used in Zone 2 or Zone 1 and also in non-hazardous areas and enables access to all field devices.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
