Raycap
Save installation space in the distribution cabinet
Raycap is launching the third generation of the 'ZPS' phase-tapped arrester series. The ZPS+F arrester can be plugged directly onto the busbar of the 40 mm system and, thanks to its compact design, can be installed in all distribution cabinets between two SH switches.
© Raycap
It provides the power supply for a gateway via its phase tap, without the busbar system having to be extended for a separate phase tap. Thanks to an integrated back-up fuse with 25 kA short-circuit capability, there is no need for a separate back-up fuse and therefore no wiring from the SPD to the fuse. The wiring to the gateway has also been simplified.
The arrester is VDE-tested and certified for protection classes type 1+2+3, providing the necessary protection against direct lightning impulses, overvoltages and end devices against overvoltages, for example the modem and gateway in the pre-metering area. In addition, the surge protection can be integrated into the monitoring software of smart homes via optional remote signaling contacts.
TDK-Lamda
Under power
TDK-Lambda presents current power supplies in the core markets of industry and medical technology. The company is announcing new power supplies for next year, as it needs to be prepared for the economic upturn.
Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
