Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
Thanks to an optional battery with up to 80 kVA, the UPS makes an external battery superfluous. The 'Energy Saver System (ESS)' improves the efficiency of the UPS to 99%. According to Eaton, the device can be seamlessly integrated into the digital solutions from Eaton Brightlayer. It is equipped with intelligent operating and management functions so that data-based parameters can be used to monitor, manage and optimize performance. The 'Cyber Secured Remote Monitoring Service' enables a rapid response to faults and provides detailed, regular reports on the status of the UPS. The 'Digital Distributed IT Performance Management (DITPM)' enables monitoring of the UPS. Users can view, monitor and manage the Edge's connected physical and virtual IT environment, UPS systems, power distribution units (PDUs) and other devices from a single central location.
