Bicker Electronics
Modular 24 V emergency power supply
The UPSI-2412 DC emergency power supply from Bicker, in combination with suitable LiFePO4 or supercap energy storage systems, bridges power failures and faults so that the uninterruptible 24 V (DC) power supply of process-relevant systems is guaranteed at all times.
The UPSI-2412 DC emergency power supply from Bicker Elektronik
© Bicker Electronics
The DC UPS board is designed for flexible open-frame system integration in customer-specific applications. In normal operation, it forwards the DC input voltage directly to the output, charges the connected energy storage device in parallel and monitors all relevant parameters, currents and voltages. In the event of a voltage dip or power failure, a MOSFET disconnects the input within a few microseconds and the connected load is supplied from the energy storage system without interruption.
To ensure that the emergency power supply from Bicker Elektronik can be used flexibly with different storage technologies, three charging processes with individual adjustment of the charging end voltage and a charging current of up to 4.5 A are implemented: Constant Current, Constant Voltage and Constant Power.
Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
