B&R
Faster commissioning without surprises
New from B&R's Automation Studio: Machine developers can now determine where they should plan power supply modules for the I/O system with just a few clicks.
© B&R
A new function in the Automation Studio software allows developers to optimize the number and position of supply modules at an early design stage. This means that the machine can be put into operation quickly and smoothly later on. The new function for optimizing the power supply is integrated into the 'Hardware Configuration Analyzer' in Automation Studio. If there are modules that would be undersupplied in the currently planned configuration, these are highlighted. The function can also be used in existing projects. All you need to do is update the firmware version of the I/O modules.
B&R
Secure communication between machines
B&R simplifies safe communication between machines and machine parts: With an update to the mapp Safety software, programmable safety functions can also be used in complex machine networks without significant additional effort, according to the...
Review
The top articles in May 2023
The fact that the fight against climate change is undisputedly the biggest global challenge is also reflected in the most-read articles of May. New applications with the digital twin and trends in AI in dialog continue to top the list.
