Carlo Gavazzi
Energy meter portfolio expanded
Carlo Gavazzi is expanding its range of energy meters with the EM500 series: EM540 is designed for direct measurement up to 65 A, EM530 measures via external 5 A current transformers.
EM500 series energy meters from Carlo Gavazzi
© Carlo-Gavazzi
With an update time <100 ms via the serial interface and a measurement resolution of 0.001 kWh, the Carlo Gavazzi devices are suitable as a data source for control or regulation systems. The 3 HP wide meters for DIN rail mounting are equipped with a backlit display. The display can be operated intuitively via three push buttons. A configuration wizard enables correct installation, parameter setting and commissioning using the free UCS software. The energy meters are suitable for two-phase and three-phase systems up to 415 V L-L. They monitor the energy consumption, the main electrical variables and the harmonic distortion of the load. In addition to the digital input for tariff management and the S0 pulse output, the energy meters are available with a Modbus RTU or M-Bus communication interface for data transfer.
Carlo Gavazzi
Precise control of infrared heaters
In order to support manufacturing companies that use industrial heating applications in their orientation towards Industry 4.0, systems that can precisely switch these special heating loads and also take over the complete monitoring of the load...
Vega
Level sensor with integrated cybersecurity
In January 2023, Vega delivered what is probably the world's first level sensor with integrated cybersecurity. The manufacturer of level, point level and pressure measurement technology wants to set an example against the increasing threat from...
