Sagittarius
Wiring system open for partners
Lütze continues to develop the Airstream wiring system into an open system platform. This means that partner companies can now develop and sell their own specialized configurations based on Airstream.
The Airstream wiring system from Lütze
© Sagittarius
The system from Lütze therefore provides the technical foundation and resources for future intelligent and scalable enclosure solutions, including solutions for Industry 4.0. With the wiring system and the separation into mounting and wiring levels, the supplier created a new standard a good ten years ago. This enables optimum space utilization, completely dispenses with cable ducts and offers thermal advantages. Since then, the system has offered intelligent, flow-rich air routing that specifically prevents heat build-up despite increasingly compact designs in the enclosure. This means that heat loss is reliably dissipated, meaning that significantly less cooling power is required.
Sagittarius
Climate-friendly planning
How can an enclosure be operated in an energy-efficient manner at any time of year without risking thermally induced failures? There is great potential in the combination of different cooling mechanisms through intelligent control. One example.
Sagittarius
Completely tool-free installation
Lütze has optimized the well-known 'LOCC-Box' family for electronic load monitoring in terms of simplified installation, connection technology and control cabinet performance. The upgrade enables the LOCC-Box to be installed in the control cabinet...
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
