Sagittarius
Power monitoring system expanded
Lütze is expanding the intelligent current monitoring system 'LOCC-Box' with an IO-Link gateway for coupling up to 15 LOCC-Box Net modules.
© Friedrich Lütze
The gateway from Lütze provides functions such as extended energy management, reading out current status information (such as current flowing or operating voltage) as well as remote control and parameterization of all connected LOCC-Box Net modules. Each individual LOCC-Box can be parameterized and controlled individually, but changes can also be made for the entire LOCC-Boxes. With a width of 8.1 mm, the IO-Link gateway has exactly the same housing format as the LOCC-Box Net modules themselves. When connected together, the devices create an orderly appearance. The position of the gateway within the structure is not decisive; it can be placed in any position. The modules are wired on the top-hat rail using jumpers with push-in connection technology. In addition to the IO-Link interface, the gateway also has a USB interface.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
Sagittarius
