Energy chains
Quelle: Igus | Inka Krischke,
Use with indoor cranes
Energy chain systems as an alternative to pure trailing cables are also gaining ground in indoor cranes, as the energy chain protects the cables inside, they are not compressed and are therefore guided safely in motion.
© Igus
With the Guidefast Control energy chain system, Igus has now developed an energy supply system that can also be used to supply the manual control system on the overhead crane. A trough reliably guides the energy chain with the cables and the driver arm, even under short-term high tensile loads. As with the 'Guidefast' guide trough for the cable routing of the trolley (hoist), the 'Guidefast control' is also easy to install: In the first step of installation, the guide trough is attached to the side of the crane girder to save space. It is then hooked into the brackets and bolted in place. Once in operation, the driver arm can be moved and positioned along the entire crane girder thanks to the lubrication- and maintenance-free 'Xiros' polymer ball bearings on the control block, regardless of the position of the hoist unit. The complete system is manufacturer-independent and can therefore be used with any crane design and control block both indoors and outdoors.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
