Fiber optic cable
Jürgen Berger | Günter Herkommer,
The data highways of Industry 4.0
Data cables lead a rather unspectacular existence as a typical C-part: inexpensive to purchase, but relatively time-consuming to provide. Does this do justice to the key role of fiber optic cables on the road to the smart factory?
© Coperion
Example of a system for the production, compounding and processing of plastic - data cables have to cover enormous distances here.
© Coperion
The machine and plant manufacturer Coperion from Stuttgart is a manufacturer of extrusion and compounding systems as well as bulk solids systems that are used in the plastics, chemical, food and aluminum industries. Its main products are twin-screw extruders for plastics production. They achieve a throughput of up to 100 tons per hour. Compounding takes place in the extruders. This refers to the processing of the plastic by adding additives in order to optimize certain properties. In addition to the extruder as the core component, the entire plant - from the upstream reactor for polymerizing the plastics to the silos for storing the compounds by type - comprises an entire area with multi-storey factory buildings.
In such a plant, it is not uncommon for data cables to reach lengths of 1.5 kilometers and more. The longer the distance to be bridged, the more a fiber optic cable can demonstrate its range advantage. This is because data transmission via copper ends at a maximum segment length of 100 meters, after which a repeater must be inserted due to attenuation.
The spatial extent of a machine alone therefore often determines the choice between copper and fiber optics, especially when other system components such as further processing, conveying or sorting are added. Another advantage of fiber optics: As Coperion only supplies part of the overall system with the Ex-truders, there may be potential differences with other parts of the system - but this is not an obstacle for data communication via fiber optics.
The 'diva' among data cables
Compared to electrical transmission via copper, optical fiber has the characteristic of a much higher transmission rate with a very long range. In addition, there is no signal scattering on neighboring fibers. As an optical conductor, fiber optics are also not electromagnetically influenced and can be laid electromagnetically compatible (EMC) together with power cables as long as the fiber optic conductor is designed without metallic reinforcement. In short, the high-purity glass of the fibers enables unsurpassed clear signal transmission.
However, as clear as the transmission is, the 'diva' among data cables is also challenging to handle. Depending on the bending radius, high bending losses quickly occur due to the radiation of light power from the core into the cladding, which has a lower refractive index. In particular, assembly by inexperienced personnel results in a significant increase in the signal attenuation of the optical fibers. And when connecting fibers using plug and splice connections, considerable insertion or coupling losses can occur.
Detailed view of a potted splitter body. This is equipped with a compatible screw connection for installation in splice boxes. The system can also be reused for new installations.
© Helukabel, Coperion
While copper cables can be quickly and easily adapted to the respective application using connectors, the assembly of fiber optic cables requires expensive equipment, know-how and experience. Acquisition costs of several tens of thousands of euros for the tool for splicing and measuring alone speak in favor of using pre-assembled fiber optic cables. Depending on the application, the cables are connected to a suitable splitter, for example, which guides the fibers from the loose tube cable without splices into individual simplex cables, which in turn are terminated with pre-assembled connectors. Finally - at least in the case of Helukabel's 'ready-to-use' solutions - the transition from the cable sheath to the split body is encapsulated with polyamide, which makes the typical cable weak point significantly more robust than an otherwise frequently used shrink sleeve.
At Coperion, the fibre optic cables are mainly used as network cables for fail-safe computer communication (visualization) within the extruders. It was clear from the outset that the control system would have to extend over long distances and that the network topology would have to ensure particularly high machine availability. The machine components of the large extruders therefore communicate in a redundantly designed optical ring.
A station failure is bridged via the redundant ring. As there are no switches between the stations and the network in this example to bridge the failure directly, the ring can do this itself using a reserve ring.
© Picture: Helukabel, source: U. Ring, Handbuch Netzwerktechnologien
Martin Wurz, Electrical Designer Large Extruders at Coperion, explains: "We want to prevent all failure scenarios of a large extruder at all costs. Especially in a process industry such as the petrochemical industry, the downtime of an extruder would result in immense downtime costs. That's why we rely on the robustness of an optical double ring network." A double-ring network achieves its high reliability through its physical architecture as a counter-rotating double ring. In addition to the primary fiber optic ring, there is a secondary fiber optic ring on which the data traffic runs in the opposite direction. During normal operation, the data traffic rests on the reserve ring. If a subscriber or even a section of the fiber optic cable fails, the data traffic also runs via the reserve ring. The data is sent back before and after the failed section. The double ring structure then becomes a single ring, but the network as a whole is not interrupted.
In addition to the architecture-related fail-safety of the double ring, the network participants at Coperion are connected to the network via managed switches. This means that if a participant fails, it can be bridged directly with the switch, so that in this case there is no need to fall back on the redundant reserve ring. This increases fault tolerance and the double-ring network can cope with more than one failure. It also provides an infrastructure in which all network components can be maintained and replaced during operation.
Wurz explains further: "As the managed switches already regulate the network security in the event of the failure of individual network participants, the redundant ring is really intended as a final lifeline in extreme cases. Or in the event that the fiber optic cable of the ring itself is broken. However, I have never heard of this happening with any of our large extruders." The latter are located in all parts of the world, often in emerging countries with extremely harsh industrial conditions. The petrochemical industry, for example, often locates itself directly where the relevant deposits are found. Wurz: "However, I have never heard of a single alarm where the transmission level of an installed fiber optic cable is in a critical range. That speaks volumes for the robustness of the fiber optic cables used.
Author:
Jürgen Berger is Head of the Data, Network & Bus Technology department at Helukabel.
Cable routing
Hybrid cables under constant stress
What properties must single-cable solutions for servomotors have to ensure that communication via the integrated encoder cable functions reliably even under mechanical stress in highly dynamic drag chain applications? Shielding is particularly...
Bopla
Enclosure Series expanded
Bopla has expanded its “Alubos” and “Bolink” product lines: The Alubos line of aluminum profile enclosures has been expanded to include a new model. The ABPH 1680 KWL variant now provides a heat sink solution for the largest enclosure size.
