Weidmüller
Snap-in technology for terminal blocks
Weidmüller is expanding its Klippon Connect terminal block range to include the AS series with 'Snap In' technology. This allows flexible conductors to be wired quickly and without tools without the need for wire end ferrules.
The new AS terminal block from Weidmüller with snap-in technology.
© Weidmüller
With snap-in, the conductors are simply inserted into the connection point, whereupon the mechanism audibly snaps shut. According to the supplier, the snap-in technology ensures a secure and permanently reliable connection - even with increasingly automated wiring processes. AS terminal blocks are compatible with the Klippon Connect A series.
The snap-in connection belongs to the category of time-saving connection technology and, according to Weidmüller, is currently one of the fastest connections. The terminal blocks are supplied with a pre-tensioned spring so that the stripped conductor can simply be inserted into the terminal point without any further preparation. The conductor to be connected is contacted in the terminal point with a clearly audible 'click'. The triggered clamping point is also visually signaled by an increase in the pusher.
With snap-in technology, the wire is only contacted if it is inserted correctly and deep enough into the contact point.
© Weidmüller
By actuating the pusher, the conductor can be released again at any time and the clamping point can be pretensioned for wiring. As soon as the conductor is inserted correctly and deep enough into the contact point, the clamping point is reliably released. The reliable contacting of the conductor guarantees a vibration-proof, gas-tight and long-term stable conductor connection. In addition to the audible 'click', a rise in the pusher indicates that the connection has been made securely. Thanks to the technology of the pre-tensioned clamping point, flexible conductors can be plugged in directly without a ferrule, without the need for a tool.
The AS series is suitable for robot-assisted assembly. Automatic assembly is possible as with the standard A series. The open terminal point of the AS series also enables robot-assisted, direct wiring. Users can use the standard accessories and the marking system of the A-series.
When developing the AS series, Weidmüller focused on the conductor cross-section range of ≤ 2.5 mm2. The snap-in contact of the terminals is designed for a maximum clampability range of 0.5 to 2.5 mm2. Further characteristics are: Rated voltage 800 V and a rated current of 24 A. The terminal blocks are snapped onto the TS 35 mounting rail.
Weidmüller
More than 20 percent growth
At the beginning of November 2022, the Weidmüller Group exceeded the EUR 1 billion sales mark for the first time in the current financial year and is forecasting year-on-year growth of over 20% in total for the 2022 financial year.
Weidmüller
Automated machine learning
Use analytics to optimize operations, improve product quality and create new business models without prior knowledge of data science? Develop and operate machine learning models without being a data expert? Software makes it possible.
Weidmüller
Prepared for failures
Weidmüller relies on in-house developments to monitor its own ventilation systems for electroplating: The performance parameters are analyzed by the 'u-sense vibration' and 'energy direkt' sensors and with the 'Industrial AutoML' AI software.
New products
Beckhoff simplifies AI training
An evolutionary development every year, a revolutionary leap every five to seven years - this is how Beckhoff aims to secure its technological leadership. At the press conference, the company from Verl also presented some technological highlights.
Beckhoff
AI training made easier
An evolutionary development every year, a revolutionary leap every five to seven years - this is how Beckhoff aims to secure its technological leadership. At Hannover Messe, the company from Verl also presented some technological highlights.
