Georg Schlegel
Small pushbutton with blade terminal
The 'Mynitron' series for 16.2 mm installation openings from Georg Schlegel has been extended by a push-button version with spade terminals.
© Georg Schlegel
The YKT push-buttons in the series have a slightly larger actuation travel of 1.8 mm and a slightly different pressure point. Thanks to the optimized haptics, actuation is clearly perceived even when operating with gloves. The push-buttons comply with protection classes IP65/67/69K and, according to Georg Schlegel, have a service life of at least 1 million switching cycles. Their installation depth is only 16 mm. The push-buttons have undergone the following tests Vibration resistance according to IEC 60068-2-6 with 5 g, 10 to 500 Hz, shock resistance according to IEC 60068-2-27 with 50 g, 11 ms and salt spray resistance according to IEC 60068-2-11. The normally open contact of the push-button can be operated with a rated voltage of 35 V and a rated current of 100 mA. The front frame color is black, the push-button surface color can be black, white, red, green, blue or yellow.
Georg Schlegel
For machine life-long use
The IP69K combi pushbutton emergency stop is designed for mobile machines and special vehicles that are exposed to difficult environmental conditions. It was developed in a joint project between Data Panel and Schlegel.
Georg Schlegel
Suitable for rail transport
The Schlegel charging sockets are available in three versions, each with two USB ports from the combinations of USB-A and USB-C: A/A, A/C and C/C. The USB-A port delivers up to 2.4 A, the USB-C port up to 3 A charging current at 5 V output voltage.
Hanover Fair
E-Paper: HANNOVER MESSE DAILY Day 5
The top news of the issue on the fifth day of the trade fair in Hanover: First summary of Hannover Messe 2023 +++ Interview: Bosch Rexroth +++ Igus: manus awards presented +++ Interview with Markus Asch, Rittal +++ The trade fair partner country 2025
