Plug connector
Quelle: EVG | Inka Krischke,
Protective cap ensures IP67
EVG has developed its own protective caps for the AMP Superseal connectors. Previously, protection was only possible via individual conductor seals within the connector; now the caps are placed on the connector and guarantee IP67 protection.
© EVG Martens
The caps are designed like a mating connector and therefore lock as usual. According to the manufacturer, the overmolded housing ensures a good feel when plugging and unplugging. TPU is used as the overmolding material, which creates watertight connections. All pin numbers of the connectors are available as female and male versions. A fastening loop with a 200 mm cable is fitted to prevent the cap from being lost. The loop is created using a stainless steel splice with a diameter of 10 mm. The protective cap is also available without a cable.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
