Plug connector
Protective cap ensures IP67
EVG has developed its own protective caps for the AMP Superseal connectors. Previously, protection was only possible via individual conductor seals within the connector; now the caps are placed on the connector and guarantee IP67 protection.
The caps are designed like a mating connector and therefore lock as usual. According to the manufacturer, the overmolded housing ensures a good feel when plugging and unplugging. TPU is used as the overmolding material, which creates watertight connections. All pin numbers of the connectors are available as female and male versions. A fastening loop with a 200 mm cable is fitted to prevent the cap from being lost. The loop is created using a stainless steel splice with a diameter of 10 mm. The protective cap is also available without a cable.
