Escha
One PVC and one Ethercat version
Escha is offering two new cable qualities, a PVC cable and an Ethercat cable. The S5200 PVC cable is designed for industrial Ethernet applications in which only low requirements are placed on drag chain and torsion properties.
It is PNO-compliant and is particularly suitable for applications in which drag chain and torsion properties are not important. A comprehensive product range with M8, M12 and RJ45 connectors is available.
The components enable reliable data transmission in accordance with Cat5e and meet the tightness requirements of protection classes IP67 and IP68.
The S1329 Ethercat cable with yellow outer sheath is particularly suitable for applications in automotive manufacturing where this sheath color is specified. This cable ensures industrial-grade data transmission in accordance with Cat5e and meets the real-time requirements of IEC 61158. Thanks to its flexible design, it is suitable for drag chains and can withstand over 5 million bending cycles. Different versions are available with M8 (four-pin), M12 (four-pin, D-coded) and RJ45 connectors.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade MediaSubscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
