Plug grommets
Quelle: Rittal | Inka Krischke,
Modular sealing system
With the connector grommets, Rittal offers a flexible solution for the insertion of pre-assembled cables in the base area of enclosures and control cabinets.
© Rittal
The sealing system has a modular design and consists of a polypropylene outer sheath with thermoplastic elastomer and a rubber seal. This allows cable cross-sections from 8 to 36 mm to be sealed with protection class IP55. The simple handling means that sealing can also be carried out quickly after wiring. The cables are pushed into the cable entry plate for fastening; the enclosure's degree of protection is maintained.
Rittal
Switch cabinet becomes a refrigerator
Rittal presented the prototype of a new integration solution for enclosures and cooling solutions at the recent SPS IPC Drives trade fair. In future, the time-consuming assembly of cooling units on side and roof areas will be almost completely...
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
