SPS Connect 24.11. - 13:30 - 13:50
SPS Connect | Tiffany Dinges,
Industrialization in control and switchgear construction
"Such things are undoubtedly great, but we are far too small for them." We often hear statements like this from switchgear manufacturers when it comes to using engineering software from Eplan or automation solutions from Rittal.
© Rittal
Today, we know from numerous projects that industrialization in switchgear construction pays off much earlier than you might think. Consistent data is the key to success and helps to avoid errors and significantly increase productivity. At the heart of this is the digital twin, which links all process steps from engineering to mechanical enclosure processing, wiring and testing through to service.
Dr Dirk Pieler, Head of the Industry business unit at Rittal, will welcome you to the presentation "What counts now - industrialization in control and switchgear manufacturing".
Date: November 24, SPS Connect 24.11. - 13:30 - 13:50
Registration and tickets
To the lecture program
About Dr. Dirk Pieler
Dr. Dirk Pieler is Head of the Industry business unit at Rittal.
© Rittal
In his career, Dr. Dirk Pieler has already been CEO of the companies Pintsch and Bender and has held various management positions at Siemens and in management consultancies.
Dirk Pieler holds a doctorate in electrical engineering and automation technology and is currently Head of the Industry business unit at Rittal.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
E-T-A
Sensory in view
Intelligent power distribution systems are valuable helpers when it comes to digitalization in the IT rack. Monitoring the IT racks using sensors is a particularly effective measure for increasing system availability.
Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
