ipf electronic at the SPS 2024
Compact multi-color LED signal light
Thanks to its 360° design and large aperture angle, the round luminaire with a diameter of 65 mm is highly visible from all sides when in use. The housing (protection class IP67) is made of aluminum and the front panel is made of robust acrylic glass with diffuse scattering characteristics. The selectable signal colors red, green and blue are preset at the factory. The colors magenta, orange, yellow or white can also be generated by connecting additional pins. The ipf light is designed for an operating voltage of 22 to 28 V(DC) and for ambient temperatures of -20 to +40 °C. The LED signal light is attached with two screws on the back.
Hall 7A, Stand 131
