Igus
Yvonne Junginger,
Draw-wire sensor for energy chains
Igus offers users the "i.Sense-EC.B" system with a new cable tension sensor for monitoring the condition of chains over 35 m in length. This allows potential chain breakages to be detected even over very long travel distances.
© Igus
Due to the extension of the measuring range from 80 to 999 mm, the second sensor on the fixed point side is no longer required. If a break is detected, the sensor immediately triggers a message and the evaluation module sends a signal to the system's control unit. Two sensors can be connected to the i.Sense GEN II evaluation module from Igus, for example for counter-rotating systems.
When connected to the digital I/O ports of the control unit, a quick system stop can be triggered. The draw-wire sensor is compatible with all EC.B systems and i.Sense modules supplied to date and can be integrated into IIoT concepts. In addition to the longer measuring distance, the draw-wire sensor is also highly weather-resistant, making it suitable for outdoor applications.
Lapp
Service as a product
Five evolutionary stages characterize a company's path from pure product supplier to problem solver. But how can the transformation from exclusive production to service be shaped in concrete terms?
