Stäubli
Connectors for docking applications
The high-performance DuraDock power connector from Stäubli is suitable for industrial applications such as electromobility, railroad technology and mechanical engineering.
© Stäubli
The connector is designed for currents of up to 550 A, depending on the conductor cross-section, with up to 100,000 mating cycles. Thanks to 'Multilam' contact technology, which, according to the manufacturer Stäubli, enables high current carrying capacity with minimal contact resistance, a long service life can be guaranteed. The connector is available in three versions: uninsulated without housing, insulated in a plastic housing and shielded/insulated in a metal housing. When unmated, the entire socket and pin parts are longitudinally watertight. Thanks to IP2X, the connector is protected against accidental contact. It can be used in various docking plates with different plate thicknesses and spacings. The use of plastic housings as an integrated protective measure reduces assembly work.
Igus
Draw-wire sensor for energy chains
Igus offers users the "i.Sense-EC.B" system with a new cable tension sensor for monitoring the condition of chains over 35 m in length. This allows potential chain breakages to be detected even over very long travel distances.
Stäubli
Plug connector for 24 V(DC)
The 24 V (DC) supply voltage is becoming increasingly important in automation technology. For a reliable power supply, continuous wiring with a conductor cross-section of 2.5 mm² is required.
