Kübler at the SPS 2022
Yvonne Junginger,
Encoders for safety applications
Based on its Industrial Ethernet platform, Kübler presents the first safe SIL3-certified encoder.
© Kübler
The Sendix S58 Profisafe is available in size 58 mm as a singleturn and multiturn in a shaft or hollow shaft version. It transmits up to 16 bits safe or up to 24 bits non-safe as well as additional multiturn information of up to 12 bits safe in the fully redundant multiturn version. The encoders are equipped with the certified encoder profiles (Profinet v2.35/ Profisafe profile v2.6, Profidrive profile v4.2, Encoder profile v4.2,). The encoders from Kübler comply with encoder class 4/S2 and provide the recorded measurement and diagnostic data via safety telegrams 36/37 or non-safe telegrams 81, 82, 83, 84, 86, 88. The CRC calculation for confirming the F parameters is implemented via a Tool Calling Interface (TCI). The calculation program can be started directly from TIA Portal. The integrated iPar server reduces errors and commissioning times when replacing devices, and a web server is also integrated.
SPS 2022: Hall 7A, Stand 506
Igus
Draw-wire sensor for energy chains
Igus offers users the "i.Sense-EC.B" system with a new cable tension sensor for monitoring the condition of chains over 35 m in length. This allows potential chain breakages to be detected even over very long travel distances.
