Tsubaki cable towing
Condition monitoring system extended
Tsubaki Kabelschlepp has added a function to its condition monitoring system that allows wear to be monitored outside the chain without the need for additional cables in the cable carrier.
© Tsubaki cable towing
With the condition monitoring system from Tsubaki Kabelschlepp, the service life of an energy chain system can be fully utilized without having to replace it prematurely. To do this, condition sensors in the guide channel or in the carrier carriage measure the degree of wear on the glide shoes as well as the push and pull forces on the carriers of energy chains. Users can program the system for different applications and set the limit values individually. Free switching outputs for connection to the user's own machine and system control are also available. The system is particularly suitable for process-critical machines and systems where high availability must be guaranteed, such as production lines or cranes, as well as in steelworks or bulk goods plants.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
