Tsubaki cable towing
Sustainable cable management for cleanrooms
Tsubaki Kabelschlepp launches 'Flatveyor ZP': The solution combines the features of a flat cable system with the structure of a cable drag chain.
Flatveyor ZP from Tsubaki Kabelschlepp
© Tsubaki cable towing
According to Tsubaki Kabelschlepp, users benefit from the simple replacement of cables. Existing cables and hoses can also be used. Flatveyor ZP is based on durable and smooth-running hoses that can be easily opened and closed using a tool supplied. According to the supplier, this zip structure is very flexible, but does not open when moved. This design makes it easy to replace or use existing cables and hoses.
Integrated support elements enable the free-standing flat cable system to move linearly at high speed. The support elements act as guides that can be moved in one direction along the specified minimum bending radius, reliably guiding the cables and hoses. The flat cable system is certified to ISO cleanroom class 2 and is therefore suitable for production processes in hygiene-sensitive industries where a particularly low-particle environment and technical cleanliness must be guaranteed.
Minimized abrasion
In the gliding operation of cable drag chains, abrasion in gliding operation as well as oscillations and vibrations are part of the status quo. A module mounted on the carrier provides a remedy by quickly and controllably placing the upper run on...
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
